is this a bad thermostat? details inside...
1996TalonEsi
99
Apr 25, 2003
My car does not overheat, but the other day I decided to check my coolant. Normally, it is full when I open the radiator cap, but this time it was low. So I added some and filled it to where it normally is. I've read elsewhere that if the radiator hose is not full, then your thermostat is bad. I've got a CEL 17 which is thermostat/engine coolant temp sensor. Again, it doesnt overheat.
Also, is it bad to run with an empty overflow tank? Just wondering, thanks for any help.:thumb:
