SNOWED & my blower motor quit blowing HELP
BOBS90TURBO
581
5
Sep 18, 2002
Tulsa, Oklahoma
It snowed today in Tulsa and I went out to have some fun and no blower motor to blow defrost heat. I replaced the entire motor with one from my gst, I also replaced the small round thing that connects to it, when I turn the switch on the dash nothing happens untill the last setting and then all I hear is a click that comes from the little round object. Is there a fuse or relay, I have looked in the vfaq and nothing. Please help quick, I have been waiting to go 4wdriving.
Can anyone tell me if there is supposed to be a relay in the spot marked heater/chauf. In the fuse panel in the kick panel on the driver side. I looked at mine and I have a relay for the anti theft but there is not one in the heater relay, should there be one there, could this be the reason I have no fan.
I just changed my motor too. Did you test the new one with a 12v source and make sure it worked before putting it in? Did you also make sure you had the correct + and - connections? Other than that it could be the swithc itself or a fuse, but I had the clicking when my motor was bad so I am guessin that is what yours is.
Yes I tested the motor and it works,my problem has to be something else, I really need to know if there is supposed to be a relay above the fuse panel that controls the heater/air a/c fan because I do not have one in mine, and it looks like I should.
You are right about the heater relay above the fuse box panel)on the drivers kickpanel). Mine was missing, I just bought this car so whoever had it before must of taken it out???? Shes blowin hard & hot now. Thanks
