AWDPSI
- 76
- May 14, 2003
Long Island,
New York
hi,
Im hoping that someone has a little bit of input on this one. I have been trying to figure this out for a week now. It all started when i had to change my Thottle body because of leaking shaft seals. I changed it and beacause my car always vaccumed at like 14-15 with no other leaks. Once i changed the Tb i decided that i would remove the emissions just incase there was any more leaks in any of those hoses. I removed the EGR, canister and all attaching valves, and installed a egr block off plate. When i went to go start my car, now it wont start. I turn the key i hear the fuel pump go on and the ecu and my safc and tt and all accessories go on but not the engine. IT doesnt even crank. I dont hear any click coming from the starter or the starter solonoid like i think i should. I mean no clicks at all. The car always started fine before this i can figure it out. I check alot of stuff what could it be. Oh and it is not the battery. I charged and used the 200amp engine start feature. Battery is fine. Someone pleaase help the next step is the TOW...
Thanks
SCott
Thanks
SCott
