Just rebuilt my motor and having some problems! PLEASE HELP
blk91tsiawd
123
Dec 5, 2003
Concord, North Carolina
I just rebuilt my motor and having a couple issues. the first thing is on the oil filter housing there is a coolant line that runs through it and i figured out one of them but cant seem to find out where the one in the back leads to, is there some kind of line that goes off it? and the other thing is im not reading any oil presure. i went with the mach v rebuild kit and it came with a new oil pump so i know the pump is good and the balance shaft removal kit was done correctly. before i started it the first time i took out the coil and turned it over for about five minutes on and off to get the presure up. then i started it for about 3-5 seconds and it didnt read anything so i shut it off. do i have to run it longer or should it have come right up? any help would be greatly appriciated, thanks
SOMEBODY HELP HIM, i got nuthin man, but im puttin my car together pretty soon and hope it goes well.:thumb: good luck
later,
Let me take a stab at the coolant part. One part should have just a hose that goes to the big water pipe that goes into the back of the water pump. The other one should meet to a long metal tube that goes behind the turbo, and goes into your thermostat housing. It sounds like you don't have your wire hooked up to the bottom of the oil pump right. There should be a wire that comes off the the wiring harness that comes from the alternator wires. That goes on your oil pump. I am sure you will have oil pressure. You could losen the oil feed line from the top of the head, and see if it starts pissing oil. If it does, I am sure you have good oil pressure.
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
