schwag9AWD
- 72
- Jan 5, 2003
The whole story is the car died and the battery/radiator light came on. I tested the alternator and it was only putting out 11.xx volts. I replaced the alternator today with one from AutoZone (65 amp) I hooked all the connections up checked the belts for tension, then put the neg. cable back on the battery(showed 11.6 V)
The car started right up the very first time, I get out to take a look and the power steering pulley and belt are not moving, but the alternator belt was. I go to shut the car off and it dies, but still has power (accesories, etc) So I look at the belts again, power steering belt has good tension and doesn't appear to be rubbing anything. The alternator belt is loose now, but the alternator itself has not moved. I tried to adjust the lower bolt to put more tension on the belt and my socket touched the outlet battery terminal on the alternator and caused a small spark.
The last owner had an AEM True-Power pulley on the old alternator so could this have stretched the belt, because it's slightly bigger than the factory one? Another weird thing is the Batt/Rad lights are still on
Any ideas? I want to finish it this weekend.
