iamtall77
- 185
- 1
- Oct 9, 2002
Las Vegas,
Nevada
2 weeks ago i changed my timing belt and all the pulleys. i also removed the balance shafts and put on an underdrive crank pulley. after doing this i sprung an oil leak from the balance shaft pulley hole. i fixed it and it began to leak from the oil filter bracket and i lost oil pressure. i put on a new gasket and no change. i didn't really drive it, but i had low oil pressure on startup.
before all of this i would get about 80psi on startup with the engine at 1500rpms. i have an Autometer oil pressure and water temp gauges. after getting warm (about 190 deg) i had 15-10psi of oil running Mobil 1 5W30 full syn. now i have about 30psi on startup and before i replaced the gasket i had no pressure at warm idle and the idiot light came on.
what the hell happened!? any ideas? i plugged the oil holes from the balance shafts, so it shouldn't be that. the oil pump is fine as far as i can tell. the only thing i can think of is the oil pressure switch (the plug above the stock oil pressure sending unit) i pulled it and nothing seemed out of the ordinary. the spring was intact and the oil plunger was clean (not clogged) i've run out of ideas here and hope i can get some help. please oh please i need my car. thanks.
Jeff
Jeff
thanks for everyones input. be forewarned and take every precaution. have fun.
