JiveMasterT
- 1,848
- 9
- Jan 3, 2004
Chest of Westerson,
New York
i was driving down a side road tonight, winding out the gears to about 4500-5000 but quickly, i put it 4th gear and decided to slow down at around the same time and the car just shut off on me. it did not bog or anything, the engine just shut off and i only noticed cause i lost my power steering and the brake pedal sunk to the floor. i popped it into neutral, pushed down the clutch, turned the key and the car started just fine. i stopped the car and then put it in first and drove away fine. this is the first time this has happened to me, and a friend of mine says it has happened to him before in his audi once. is it something to worry about? should i do something about it?
HI remember me
.Talk to good mechanik,sounds to me like fuel presure problem.My camry does same shit.I drive and I slow down almoust stoping at trafic light and the car shuts off just like that.In my case the reason is bad fuel pump and when the pump gets warm it stop working and then it needs time to cool off and then it works again.Some times it stop and I turn on again with out waiting just like it hapened to you.Some times it does it often some times doesnt do it for like a month.Ain't that a bich
