SDSGSX
- 179
- 2
- Nov 16, 2002
Raleigh/Fayetteville,
North Carolina
HeY guys......quick run down....Car idle seems normal to low sometimes like 500 rpm. The thing is when i drive the car normal like on the street shifting at 4ish ( no real boost) the car is fine. When i boost the car then let off gas and go into neutral the RPM's go WAY low...like all the way down to 300 rpm and now if i boost hard and go to neutral it stalls out. Ive checked for blown hoses and all is good. The BOV is not vented and is an uncrushed 1gbov. The thing is the bov seems to be leaking air badly all the time. I hear it whistle. My question is do they go bad?? And if they did go bad is that whats causing my car to not wanna idle after boost? any suggestions would be great because once i fix this i can buy my new turbo. Thanks guys =)
Lj
Lj
