92awddsm
DSM Wiseman
- 4,877
- 93
- Jan 17, 2004
Chesterfield,
Virginia
Im a newbie here but I know my car and how to work on it. First off, about a year ago, my car would not start one day. It wasnt getting fire, so I replaced the coil pack, plugs and wires. Still wouldnt start so I left it alone. Two days later, it started up and ran fine. Over a month, it got so bad that it would only start about 10% of the time. I parked the car for a much needed rebuild. Found that ecu had caps leaking which damaged the circuit board. I had the ecu repared, socketed, a new chip burned, and tested in a car by dsmchips.com I put the engine back in the car and kept all the stock parts intact for breakin and troubleshooting purposes if needed. Car started fine but had a miss so I turned the car off to look for problems. Never would restart afterwards. Now I have replaced ecu with a stock one out of a known good running 92 awd talon, replaced cas, transistor, injectors, fuel pump, fpr, another 3 differant coil packs and numerous other items like battery, plugs, wires. Now all the plugs are firing, great compression, getting fuel @ 43 psi, double checked and triple checked cam timing and timing belt, checked all grounds, replaced mas, and every other trouble shooting idea that I or anyone else has had. No trouble codes, and everything checks good so the car should crank and run. I am ready to pull the harness and look for broken or burnt wires and check continuity on all. Has anyone else had a problem like this? Can someone give me a heads up on what to do or anything else to check? Yes, I checked all fuses and electrical connections. I have spent a month chasing and replacing with no luck and its driving me crazy. PLEASE HELP!!!!!!!!!! I want to drive my car once again. Thanks
Keith
PS car is a 92 talon tsi awd 2.0 turbo 5 spd, 100k, never been wrecked or modded, till now
Keith
