awd4g63
- 1,335
- 2
- Oct 22, 2002
Savannah,
Georgia
Here's the situation: I'm changing my clutch, so I get everything stripped down to where it needs to be, and I go to take the transfer case off. It comes out a little, and I pry the rest of it out and the transmission basically 'falls' out.
Here's the problem: There's the input shaft that the transfer case is supposed to pull off of. The input shaft comes out with the transfer case. It pulls out of the transmission side instead of the transfer case.
I can't get it out, what do I need to do? I'm need some help pretty badly, I need the car running as soon as possible, but I won't be able to put the transfer case back on unless the input shaft is already in the transmission.
Any ideas and help is greatly appreciated!!
