Inwo
- 69
- Aug 5, 2002
Youngstown,
New York
I have done some major refurbishing on my 1990 Talon TSi AWD over the past few months installing an SAFC and a MAFT among other things. About a month ago, just before the temperatures took a nosedive to the current -20º wind chill I had a chip installed by Jeff O. He said the caps had just started to leak, so I had him replace them at the same time as the chip install. I installed the ECU, everything apparantly worked fine. Readings for everything were nominal, car started up and idled fine. So I disconnected the battery and went to install the EGT gauge.
Apparantly during the time I was installing the gauge my battery was close enough to the IC pipe that it contacted the clamp, I didn't notice or think anything of this when I popped the terminal back on. I went in and checked the dimming of the lights for the egt, had my drill out ready to drill a hole while the car was idling for the egt gauge. I thought everything was going to be fine.
I tried to turn the car over, it started to turn over, then suddenly I hear CLICKCLICKCLICKCLICKCLICKCLICK then nothing. I was terrified. I stopped turning the car over and ran over to disconnect the battery. After I moved the battery back I noticed it had drained. No problem, put the charger on, didn't smell anything burney so I figured it was just the battery shorting out, as the fusable links looked ok. I put the battery back in after charging and now...nothing.
The lights turn on, but the car doesn't turn over. ECU doesn't turn on. Radio doesn't turn on. Strangely the door-open light on the dash stays on constantly.
I have attempted to replace the fuseable links with autozone jobbers, the 20 and 2 30s, but like I said the old ones didn't look broken and the new ones from autozone don't look quite right.
After doing a search I am thinking that it probably IS the ECU but I want to be certain that there are no other fuseable links that might be the cause of this, and that the autozone fuses are good enough...
If anyone can think of any connection that might not be good enough or a solder that might have broken or anything like that for me to try I would be eternally grateful as I haven't actually DRIVEN my car in well over 4 months while I installed this stuff and waited for parts.
Thanks for the help in advance,
Inwo
Inwo
