blktalon
- Jan 1, 2004
galion,
Ohio
ok, i installed a 2.5" exhaust, 16g with intercooler piping and greddy bov. already had k&n filter and autometer boost gauge. the problem is when the boost starts to build, it goes to 22psi and above as the rpm increases. the stock t25 turbo always spooled to 15 psi and held there. the boost nipple for actuator is in the same place, so i removed all control and hooked the nipple to the actuator direct. no difference at all. what is going on? i checked the wastegate actuator and it starts moving at around 15psi. is this about right? any ideas will be appreciated---thanx
