racer
- 328
- Aug 8, 2003
Ok guys I'll try to explain this somehow.I dont drive car for few days,then I start it up and it starts perfectly like new car.It idles normal at around 1300 rpm and with the the temperature going up the rpms are going down as it should be.Now the thing is that while the car is heating up the rpms are droping for like a sec and it drops like for example
from 1300 to 1100 and then goes up to 1300 again,then it does it again after like 10 sec. If the engine runs ok it goes like brrrrrr and when this shit comes is like brrrrrrrBOU .It is like someting cuts the air or fuel for a second.It does it only at idle.Then when it warms up doesnt do it at all or if it does it,it is very easy, hard to notice.I had brand new steper motor like an year ago cuz the old one was bad.After that it was runing fine until now.I checked the ECU and it is fine everyting is working normal so I do not think that it is the ECU.I chek the plugs and wiers everyting is perfect and it sparks perfect.My timing sensor and trotle position sensors are in perfect condition and all work fine.
PLZ PLZ SOMEONE HELP ME.I can not drive my car if there is someting that isnt normal,I just dont feel comfortable driving it while there is someting that isnt right with it.
