scottr126
- 366
- 2
- May 24, 2003
CHICAGO,
Illinois
I bought a Walbro 255 Lph fuel pump a while ago and I was told if I got the Low Pressure Unit then I would not need a Fuel Pressure Regulator. But at the same Time I bough it I bought a fuel pressure gauge and a fuel filter. Well basically I installed the 255 and also did the re-wire and now at Idle with the Hose connected the gauges reads around 49-51 psi at Idle. Is this ok??? What are some negatives/positives about this?
