1G where is the oil pressure port?...
DSMbish90
93
Dec 20, 2003
bel air, Maryland
where is the pressure port on the engine?...i need to hook my oil pressure hose up to it,..i have no clue;( thank you.
"pressure port" is kind of broad, you should be more specific.
To test oil pressure, you have several options. You can pull off one of the stock senders, and plug the gauge up there. You can also install the gauge in the head at the stock turbo oil feed.
ok guage is in and working.... now.....is it normal for it to idle at 25 psi...and rise when the throttle is down, and decende when the throttle is let off??. TIA
The oil pump is mechanically driven by the cam belt, spins faster as the motor does. Fairly much a direct correlation.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
