tomcat80
- 60
- Dec 16, 2002
Stavanger (Norway),
Europe
I think my car is leaking antifreeze. I was actually going to change my slave clutch cylinder when I noticed this green liquid under the car. I found drops all under the engine, couldn't find the source. Where should I be looking to find the leak?
And one more thing...My clutch is slipping and the clutch pedal is stuck to the floor, so i was told the slave cylinder was leaking. But when I look at the clutch oil reservoir the level is max. (If i'm looking on the right reservoir, the small one besides the brake reservoir?)
places most likely to leak. check the lower/upper radiator hose and make sure hoses are secure and on right(just a little off causes leaks), termostat housing also needs to be checked along with hoses that lead from it. there is a 3/8 s hose behind the oil filter which is prone to leakage( and if leaks it leaks it leaves everywhere!. radiator itself checked for holes. check resevior for holes on bottom.
