tsilover
- 254
- Oct 20, 2002
I did a compression test on my car when i noticed that blue smoke was coming out of the exhaust. Here are the results, from cylinder 1-4. 125 145 185 185. I know i have a problem but I don't know what it is. I did the test numerous times so i know the numbers are accurate. I put the oil in the cylinder and the pressure when up. This leads to piston rings. I also read that if two adjacent cylinders are 20+ different then it could be a head gasket. What do you guys think?
Also, does anyone know of a device to read engine codes?
Thanks alot
Thanks alot
