4twenty
- 55
- Aug 23, 2003
I recently finished my 6 bolt swap and the car was running great until yesterday. At idle it sounds like it is misfiring. I checked the plugs and they were black so I put some new ones in. I could hear a vacuum leak around the throttle body. I think it is the tb shaft seals leaking. Would that cause my problem? When I drive it seems normal although I am babying it now since the engine only has 70 miles on it. I am using NGK BPR7ES plugs. The timing was never set but the vacuum gauge was reading 19-20 at idle. Now the boost/gauge reads 10 at idle and it is stumbling. Thanks for helping.
Jared
97 GSX
90' 6 Bolt
EVO3 16G
PROBLEMS
Jared
97 GSX
90' 6 Bolt
EVO3 16G
PROBLEMS
I checked all wiring and its the same as the one i found on the road race website? but what i dont get is why does it die??? everything seemed to be good..
