new plug wires, new studder
tsiawd2002
Aug 9, 2002
I just changed plugs and wires because it was that time and now I inherited this annoying studder while accelerating. I went from the stocker wires to an oversized "performance wire" from APC. (Dont lecture me on the whole APC thing, they were dirt cheap) I put champion plugs in it because no one had NGK's around here(figured they would get me by for a while till I could find some NGK's) Went for a drive to make sure everything was OK and discovered that when I was at WOT the car would studder around 4k-5k then keep going. It does it in every gear, just not as noticeable in first gear. I checked plug gap first. AUTOJUNK's book said said .34. Tried that then lowered to .29. Nothing changed. Then I blamed the wires. I checked them w/ multimeter, they checked OK. Dont know what else the problem would be now. I would have tried to put the old wires back on but a couple of them fell apart as I took them off. PLEASE HELP!!
I installed the Accel 7920R plug wires along with NGK BPR6ES spark plugs...problems all solved.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
