rocketrx7
- Dec 9, 2003
Akron,
Ohio
I've got a question concerning what should be an easy procedure. I had to replace a rear brake line last week after it corroded to eventual failure. Once I replaced it, I tried to bleed the air but couldn't get anything out at all. So I checked the master cylinder, bled the lines before the proportioning valve just to make sure. The front brakes work fine but nothing is going to the rear lines from the valve. It appears as if the valve is plugged at both rear outputs, but I can't understand why. I've bled them in the proper sequence and I've even tried a different proportioning valve. They were working fine before since I was expelling fluid out the corroded line. Is there a procedure I'm unaware of?
