georgie2577
- 39
- Jul 23, 2003
Alamo,
Texas
First I'd like to say hi to all the DSM'ers on this site. Truly an awesome resource!.. Thanks for all the great information.
I have a 91 gsx.
Small 16g
Apexi N1 3inch turboback
Joe P MBC
Autometer Boost guage
I was doing pretty good with these mods until my boost spiked to 20 psi and I messed up the engine (detonation). I've been doing alot of research on this site to help me get to where I am right now. I noticed the white smoke out of the dipstick and oil cap so I researched it on this site and found to check the PCV valve and it turned out ok. Next step was to check the compression.
1- 159 psi
2- 159 psi
3- 84 psi
4- 168 psi
It seems to me that I blew the rings on that cyl 3 which is a great reason to pull the head!
I would like to know if it would be a bad idea if I stayed with the stock piston and ring size and just had some OEM stuff put back in. I'm only looking to run 12's at the fastest. One of the biggest motivations to staing with the OEM parts is because I'm not financially capable of upgrading to the good stuff and having the engine pulled out. I'm going to be doing the work myself and I'm gonna have to stayed as cheap as possible on this rebuild. :/ Any comments would be appreciated.
Thanks friends.
g30
I have a 91 gsx.
Small 16g
Joe P MBC
1- 159 psi
2- 159 psi
3- 84 psi
4- 168 psi
I would like to know if it would be a bad idea if I stayed with the stock piston and ring size and just had some OEM stuff put back in. I'm only looking to run 12's at the fastest. One of the biggest motivations to staing with the OEM parts is because I'm not financially capable of upgrading to the good stuff and having the engine pulled out. I'm going to be doing the work myself and I'm gonna have to stayed as cheap as possible on this rebuild. :/ Any comments would be appreciated. Thanks friends.
g30
