kr.k
- 215
- Aug 9, 2002
seems like my MDP sensor is dead. can anybody tell what is it`s purpose and should I change it asap or should I replace it at all? It is rather expensive piece and if it sits there ONLY to control the duty of turbocahrgers waste gate acuator solenoid (soon to be disconnected) I see no reason to change it at all. So please let me know if it has other important tasks!
thanks
thanks
here's the fact's: the map sensor(manifold absollute pressure) sensor on the 2g is there for the purpose of checking the function of the egr valve ONLY, it does this by checking for a drop in vacuum levels within the manifold when it commands the egr solenoid to open the egr valve....if it does not see a drop in manifold pressure during this time it flags a check engine light......this is the reason the 1g does not have the map sensor...the 1g when it was in production did not have to meet the same strict emissions laws that came along with the obd2 systems introduced on the 95 and later vehicles.....it does not use the map for fuel control at all so all you have to do is remove it or leave it on and replace it .... you will end up with a constant cel if you choose not to replace it with a good one unless you have your ecu reprogrammed to not check the egr operation(there is also other ways) just lettin ya know!
