Knuckles2.0
- 101
- May 6, 2003
McChord,
Washington
ok this is a tuff one. my car was running like crap. i would pull to a stop sign, push in the clutch, and it would die. I thought it was the isc motor, but it reads 35 ohms so that should be good, i think. the tps reads bad resistance it sits at 4.0 ohms but doesn't go up while i move the throttle the resistance doesn't go up. so thats bad.
when i read the voltage coming from the ecu to the icp motor i get 12 volts on pins 2 and 5, and only fractions of a volt on the rest. On the tps connector i get 12 volt on one, 5 volts on one, and again only fractions of volts on the other two.
so here is what i think i have a bad TPS and a ecu with leaking caps or worse, and a good icp motor. does that sound right? does any one have any experience with this? sorry for missspelling ...
i thought it was like 28-30
