Cant Get It Into Gear
eclipsegsx9797
904
2
Nov 9, 2003
Romeoville/Chicago, Illinois
was up guys, when i start driving my(racing, getting on it) i get cant it into gear, any gear. i feels like someting is getting in the way. my drivetrain mods are, jun flywheel, act2100 clutch, metal bushings, stock clutch line.
not realy, just when im on a hill LOL, if it did what would that be. also i have that bearing kit for the crank walk soulition and it eliminates my pedel when i start the car(i could start my car without pressing the clutch in)
well....if ur just sittin....and u put the car in 1st gear while holding the clutch in....and the car starts to move....then ur slave cylinder is not disengaging ur clutch all the way...2 things u can do is check for any kind of leak on ur clutch hydraulic line....if not...then bleed ur clutch line again...it might help it a lil....
this...is...really...annoying...
Anyway, check to see your clutch is adjusted properly. Along with that, you'll need to make sure either cylinder isn't leaking externally. Internally you'll be able to notice it by putting it in first and holding the clutch in for a bit. If it moves, you need two rebuild kits.
Clutch Adjustment
when i push my clutch in and i let it out just a lil bit with my foot off the gas, the car moves forward a little bit. is this normal?
bro listin to us, when you HOLD The CLUTCH ALL THE WAY IN if the car moves while the clutch is fully engauged then you may have a bad master\slave cylinder(s) if the car dosent move then its fine,
look at the master\slave cylinders for leakage, also take your car to a clutch place and have your pedel adjusted. check your tranny fluid that is another contrubiting factor
when its all the way in it doenst move. when i let off a lil without putting my foot on the accelerator, it creeps up very slowly.
since i just bought this car, im just going to take it to get a complete tune up. I dont think the previous owner took care of it seeing as how there was barley any coolant at all.
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
