buzzin when brakes applied
sleepintalon
Dec 4, 2003
oak creek, Wisconsin
k heres my problem, when i'm applyin the brakes i have a buzzin not squeakin sound. it happens even when i am sittin at a light and i have the brakes on. the brakes are still strong but the buzzin is annoyin. it doesn't seem like the buzzin is comin from the brakes themselves but its hard to tell really. if anyone has any ideas it would be appreciated thanks
Does your car have ABS... might be the pump unit, might be a booster.
You need to have someone press on the brakes while you search for the noise source.
Cheers,
GTM
i do have abs, where is the pump?? what is a booster??
Jam a stick between the front of your seat and the brake pedal so you hear the noise. Open the hood and listen. Put you hand on parts so you can feel if they are making noise. I don't know your car, look for a large aluminum casting with several brake lines attached. The booster is attached to your brake master cylr, usually black in color mounted on firewall and 8"-10" diameter x 5"-8" deep.
Cheers,
GTM
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
