SchmeelDeal
- 61
- 1
- Dec 17, 2003
Morgantown,
West Virginia
I gotta '92 Laser RS AWD Turbo 5spd and over the past six months I have noticed a "THUMP" or "KNOCK" when the clutch takes hold. This only occurs when accelerating. The car goes into gear like butter; I can pretyt much shift with one finger if I wanted to. Also when accelearting, there is a small grind like noise (like sticking a pencil into a fan) when shifting into and up through the gears. It is louder going to 1-2, then gets less and less through 2-3, 3-4 and is not present from 4-5. I think that the grinding when shifting is probably because there is a lot of play in my shifter and it needs adjusted, but I other then the universal joint, I don't know what the thump could be. (universal joint has just been replaced).
Could anyone give me some insight on what could cause this thumping noise.?
I am currently getting the engine rebuilt along with installing an 2600 ACT clutch kit, SS clutch line, and ACT Exact Flywheel. Do you think this will fix the THUMP?
(is it black?)
, or the front cb bushing.
