big probs
greenGTS
Dec 17, 2003
klamath falls, Oregon
my 95 GST runs like crap. if i feather the throttle it will rev up fine. if i floor it, the engine hesitates and misses and it sounds like a popping sound. when i drive it, wont rev past 2000-2500 rpms. runs fine below that. at idle it sometimes dies and it misses. replaced plugs and wires. fuel pressure is 45 psi at idle. timing is 5 degrees with ign. timing check connector grounded. what could be wrong?
you can also try searching the forums for that "pop" noise. i believe i have came across another post describing a "pop" noise before. not sure if its going to match up with your problem but it might. good luck!
