FASTSPOOLINGST
- 598
- Sep 17, 2003
Elizabethtown,
Kentucky
I recently did a turbo, mani and O2 housing swap and after I put the components on my downpipe would not bolt up to the Evo III O2, so i drove it to the muffler shop unbolted. I got a check engine light so i assumed it was the O2 sensor in the exhaust not getting a reading due to it being disconnected. I then had my pipe welded to the new flange and bolted it up. I then took my car to auto zone and had them use their OBD II tester on it and sure nuff it said O2 sensor. I then had them erase the error code. I then took off driving down the road and it popped back on again. I have the same O2's that I had when i took everything off, i did not pinch any wires or anything so i don't know what the f is going on. Somebody hook a brotha up
Only thing i can think of is when i was spraying some Gunk on it, some got in the connector plug????????
