AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
I got my car a week ago and it was running really bad would barely idle,idle surging and could hardly drive it around at any throttle setting it would surge and sputter and buck a bit.
Since then put in redline injection cleaner,premium 92 octane,new battery,new air filter,new fuel filter,new pcv,new therm,new accel wires and new ngk plugs.Did Mopar CCC to the car and then engine flush and new synthetic oil.Checked timing and tps and timing was way out but is stock now.Checked upper hoses on intercooler tighten them all up and even checked exhaust manifold for big cracks.Turbo spins up and seems to be boosting fine at part throttle but go full throttle and machine gun sound and car don't go at all.
Vacuum was steady at around 16 or so..am at 2000ft above sea level.
Took off cat and catback also to make sure wasn't clogged cat.
Tested ignition coil seems ok and tps.
What the heck is left to check here.What would cause this machine gun sound and no power at wot.Can a bent valve car pull steady vacuum have perfectly smooth idle and run fine not wot???
No check engine lights either.Nada..
Haven't checked my underneath intercooler pipes yet and haven't checked fuel pressure.
Appreciate any help you guys can give.I even ordered mods for car thinking the problem was just a tune up but starting to wish I hadn't bought this thing.Its undriveable the way it is.
. check the cheap stuff first before buying all the other big stuff.
