GSXlaunch
- 392
- Sep 3, 2003
As the title states...I decided to test my AWD in the rain after just getting it back on the road after some head work. Man, that was fun...zero loss of traction...I had a blast. Anyhow, once I got to work I decided to check things over under the hood. I pulled the dipstick with the car at idle and looked at the oil. The oil was spotless except for these tiny sand grain size bubbles. It was not milky The car does not tap or tick...idle is great. Power is great. The only time I get smoke out the exhaust is in the mornings when it is cold and then it is only steam and goes away after a short drive. There is also no smoke or leaks in or around the engine. There is no sign of oil in the water. There are no engine oil leaks. I am using the metal head gasket from Conicelli and I used copper spray on both sides with ARP head studs. I also have the open eliment K&N, and the breather line on the valve cover is left open for now. There aren't very many bubbles just a few clumped together. I cleaned the dipstick off with my fingers and the oil does not seem to be watered down. I also pulled the oil cap off and did not notice any bubling on the cap or in the valve train. i do have about a 75% water to 25% antifreeze mix in the radiator. The only thing that concerns me are these tiny bubbles on the dipstick. Is this normal in very humid areas or after a drive in wet weather? Thanks
