adam355
- 315
- Aug 26, 2003
Urban,
Wisconsin
I took it up to 115 and the engine shut off once i started to slow down. Now whenever I give the car gas the engine makes a sputtering noise. Im also getting a lot of feel through the clutch when i give it gas. Besides that it seems to run alright. Like its driveable....not that im driving it. Think im going to have to rebuild? When I reved the engine to 3 grand a tiny bit of smoke came out...and it sounds just terrible.
edit: By the way the reason I think this happened is because my car creaps really bad and I think I overboosted. Look at my profile to see my mods.
It takes some of the burden of choices off you and you get on with your life. Read the fine print on the warranty, try to establish who can do the maintenance. This can be as simple as a small note pad/note book where you recored gasoline purchase, milage, oil change, purchase, date done etc. Doesn't take a lot of time to make an entry but it shows a systematic concern so if some issue comes up you have the data written down.
