Motohead1
- 103
- Dec 11, 2002
Ok my 90 Throtlebody is surging bad but only if the car is moving as soon as i come to a stop the thing settals down and sits on a rock solid 750rpm. I just took the TB off today to replace a what seems to be perfectly good IAC motor. Just to see if it would help. so i decided to tearit all apart and see if i could make a plate for bypassing the cold start warmup. but there seems to be no wax pelet type in a 90 throttle body. Instead theres a mechanisim with two oposing springs and a pintal that looks like it might move like a thermostate. its all held in with a plug thats adjustable by alot. meaning i can change the tension on the thing by almost a 1/4 inch in either direction. were should it sit? i caint find an adjustment for it in the manual?
thanks
thanks
