jaders
- 78
- Nov 28, 2002
Des Moines,
Iowa
I have searched the forumn for my answer but have found nothing. The sound I am hearing is like the sound you would hear going over a bridge or when you drive over a rough patch on the road. Kind of like a urrrr sound. I have not noticed it happening at a certain rpm but it does seem to happen when I get to 0 on my boost guage it will go away after I go over 1psi. I thought it might be my clutch because it was bad. But I replaced that, and the sound is still there. At first it only seemed to do it in fifth then fourth then third and sometimes in second. I replaced the timing belt and the tensioners and idler pullies and harmonic balancer about four months ago. My sound started about a week ago. Not sure if that has anything to do with it. Is there anything specific that I should look at. Thanks for any help. Jaders
