ezell4G63
- 62
- Jun 6, 2002
I have a problem with my battery being drained overnight. I traced it down to the mpi relay not fully resetting. If I turn the key to the on position I hear the relay click, then when I cut the key off it doesnt reset.
Car cranks, runs, idles, revs, all perfect, just will not hold a charge.
If car is off the battery reads 12.8 volts, if I turn the key to the on position the voltage drops to about 12.6 to 12.7. And will continue to drop about .01 volts per minute.
If I pull the MPI fuse or unplug the mpi relay the volts jump back up and hold all day long.
What could cause this relay not to reset?
Car has no other problems at all. Like I sat it runs, drives, boosts, etc...
Thanks for any help or ideas!
