zadir
- Jan 27, 2003
This morning I walked outside and noticed a pool of oil under my car, I checked it, it was a little less than quart short.When I began to investigate I found the Oil filter loose. I took off the old filter and noticed that the whole assemly was loose and shook when you touched it, I screwed the part that the filter screws onto hand tight, and then tightened a new filter on good and tight.. What happened? Do I need to fix something else or will it be alright for awhile?
