Ignition fuse blown
guy1innc
30
Aug 19, 2002
I have a 95 GS auto, recently try to start my car
My ignition fuse keeps blowing and I have no clue why ?
I went threw three of them already. Once i put a new fuse and turn the key I get a tick tick then pop goes the fuse. Any ideas why
put a higher rating fuse im not sure what yours is but try going like 30 amps higher.. it worked for my friends gst and dont go to autozone go to lappens ... if that dont work probably check your alarm... music system .... ?
Unless you want a fire DO NOT put a higher amp fuse in it, if you have an after market alarm that is probably the culprit.Unplugging the alarm won't help, its more than likely in the alarm wiring and not the alarm itself.
So i should remove the alarm and the alarm wiring...I think i will check on that next...I unplug the alarm but did not remove the alarm wiring.
Thats the worst thing you could ever do.
:dsm:
I recently had by car in the shop for omost a month because of this and
my car shouts down after 10 minutes of running ewrytime blowing the fuse. Be carefull you can start fires with that. Mechanic has no clue eather.
Originally posted by 98EclipseTurbo
:dsm:
Find a new shop and mechanic, electrical problems are not hard to track down.
dude check for any metal parts that maybe interfering with your connection. i remember once in my firebird, a screw dropped in my lighter thingy, and it would always pop my accessory fuse, so check for any tools you may have left, check your ignition relay for interfering wiring.
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
