Charles1
- 160
- Oct 24, 2003
i have a 1995 non turbo talon esi
i re did my gorunding cables and power cables worked out fine right. apearently not everytime i start the engine the engine fuse 30amp start to get really bright and then pops and car dies.
i have gotten this responses from prefesors at school in engineering.
1. that bigger wire conduvt beter electricity thus placinf more flow of electricity on the fuse thus the fuse blows. fix it by placing a 80amp fuse.
2. the two wires that i re did might be overlaping or some how short ircuting although the ay ar not tough chin directly. just th e fact that they are on top of each other they might short circuit. fix it by placing them as far away from each other.
3 bad ground or missing grounding. fix by searching ones stupid idiocy
i di nothing wrong or misisng
4 its something beyond this world
is thres anything you guys might think it can be
i gutten out my cat but that would affect engine fuse or would it?
as wiring oes i made sure all were in right order and they are what else can it be or is just answer 1 bigger fuses and that will fix my problem
i di nothing wrong or misisng4 its something beyond this world
. is thres anything you guys might think it can be
