TheCrazyDSM'r
- 252
- 1
- May 11, 2003
Tokyo,
Asia
My problem is pretty wierd if you ask me. I have installed aftermarket fans. Well I wired them into a power supply. but when you remove the keys and turn off the car, the crazy SOB doesn't turn off( the whole car that is) but about 5 seconds later the car turns off. You can listen to the fans start slowwing then the car turns off. I don't really now how to discribe the problem.
. I wired in the fans to start once the car turns on because I don't want to worry about cooling problems on the hotter days. I also wanted it though that the fans turn off with the car and that I wouldn't have to worry about turning them on or off. Sometime I forget and I don't want to worry about them. When I said other spots, meant other relays. I like tried the A/C relay and so forth. All showed me the same result. I'm thinking on just buying the fan install kit from napa. I'm not sure I really want to figure out what is wrong first. Also, the only other then that was change resently was the alternator. I got it from Advance Auto Zone.
