boostinboy
- Jul 3, 2003
I just installed an ACT 2600 into my 93 talon AWD. As soon as it was installed, it was immediatly tough to get into gear and when in gear it would stall at idle. The mechanic who installed it said it was the clutch master cylinders old age on a 2600 lb plate. Once the master cylinder was replaced the problem was fine for about 20minutes of driving and then same problems arised once again.
My thoughts on the problem are that maybe one of the fluid lines from the clutch cylinders or slave cylinders is toast from the pressure trying to decompress the clutch even though a new clutch cylinder is in.
Any ideas or suggesstions about what the problem would is much appreciated.
Thanks.
Thanks.
