turbohounds
- 48
- 2
- Oct 11, 2002
O'Fallon,
Missouri
I'm at wits end - hopefully someone can offer some suggestions what to try next. Pretty much ever since I purchased my '92 it has had a random stalling problem, which comes in episodes about every six months. It will die, and restart again within about 30 seconds and be fine. All of the normal maintenance items have been replaced several times (plugs, wires, timing belt, no boost leaks, etc). My first thought was ECU capacitors, no help. Second, bad ignition coil, no help. Third, maybe my wiring had a bad ground, rechecked everything and it's all good and properly soldered.
For the last two days crusing at a steady 60mph, I lost all power. Apparently, at speed the engine could stay running, the RPMs looked fine, speedo worked, but I couldn't maintain speed. At no throttle, it slowed faster than without, so I think it was running some, maybe on a cylinder or two. I could still hear the fuel pump, and there was no click in the ECU or flashing of the SAFC. After 10-15 seconds, and slowing to about 45, it popped a few times and began to run fine again. I'm thinking it's getting fuel (hence the backfiring and loading up while it's not firing) but not firing on all cylinders properly. When stopped there isn't enough momentum and it stall. I'm thinking there must be an intermittent problem in the ignition system. Possibly the power transistor? What am I missing?
Car is a '92 AWD Talon, with 550s, big 16g, 2G MAF, SAFC, and lots of other little things. Problem was around before and after any and all mods.
