Head Bolts
ChvyKc
651
14
Nov 5, 2003
Cayce, South Carolina
Just got a quick question. I know on a Starion that you can't use the stock head bolts but one time. After that, they stretch out and won't torque down right. Is this true for 4G63's?
I am just trying to figure out what all I need to buy before I pull the head off of my car. I just found out that the motor that I just bought has a cracked head.
Any help will be appreciated
David :talon:
My 91 AWD Manual doesn't say anything about the Head Bolts not being re-usable - I would highly reccommend getting a 1/2 inch drive 10 MM Allen IMPACT Socket - a good 1/2 inch extension & an electric 1/2 inch Impact would be very-very nice - even if you rent it - There's a long list of seals, hoses, gaskets, water pump, belts, etc that you would be crazy not to change out while you are in there - particularly if all that is original & leaking like mine was - not to mention canning the water/ oil cooler & rear balance shaft - Here's my parts list - about $2.5K with upgrades & overkill - hopefully yours is in way better shape than mine - Good Luck - & also - about where in S.C. are you?
MITSU PARTS........... (about $2K)
MD141454.... PLASTIC TIMING BELT COVER...........
MD141457... PLASTIC TIMING PULLEY COVER & FASTENERS.......
MD125933.... VALVE COVER & FASTENERS........
MD040550... New 1G PISTON rods FOR 91 TURBO.......
MD129231... Stock pistons & WRIST PINS FOR 91 TURBO, ........
MD129423.... Rod bearings FOR 91 TURBO .........
MD140923... Factory Mitsu RINGS FOR TURBO ...
MD308197... 95 EXHAUST manifold FOR A 4g63 Turbo engine
MD194403... GASKET, T/C OIL RETURN PIPE (QTY 2) ....
MD092806... - NUT, EXHAUST MANIFOLD, SELF LOCK 8 (QTY 10)
MD041192 - WASHER, EXHAUST MANIFOLD, PLAIN 8 (QTY 10)
MD005317 - STUD, CYLINDER HEAD, 8x28 (QTY 10)
Another manifold to turbo bolt, and a spring washer
MD997479... Complete gasket set.- Exhaust gasket is the same for 1G's and 2G's.
MD030764... O-ring that goes in the water pipe behinD the water pump
Optional: Mitsubishi Rally-Art Head Gasket is almost twice as thick as the stock unit and will solve the piston to valve clearance or cam timing issues than can happen when the head and block are resurfaced. If you are using oversize valves or larger camshafts this can be even more of a problem. We use this gasket on all of our motors because of it's superior sealing - 95$ from turbotrix. Fits all 4g63 engines.
MD997619... Water pump
MD090767... NEW Crankshaft accessory pulley/harmonic balancer
MD164533.... HYDRAULIC Timing belt tensioner.
MD098626 Balance shaft stub shaft - ReplaceS the rear balance shaft with the Mirage 1.6L engine oilpump stub shaft and if they say they don't fit your car, tell them to order it anyways.
MZ690116...... (1) Oil Mitsu Oil Filter
MD??? ....... knock sensor
MD129355 Timing Belt Idler Pulley
MD156604 Timing Belt Tensioner Pulley
Oil Supply PIPING for Turbo
Inner Center Bearing Dust Seal
Outer Center Bearing Dust Seal
Transaxle Seal at Driver's CV Shaft.
______________________________________________________
BUMPER TO BUMPER Aftermarket PARTS (about $500)
Fuel Filter
Impact Socket & the electric Impact
8mm threaded rod and 6 nuts on the end to make a tensioner tool.
3 QUARTS GL-4 or betterTranny fluid - MULTI GRADE
2 QUARTS SYNTHETIC gear oil GL-4 OR 5 is good for the x-fer case and rear diff.
Ultra Gray RTV for the oil pan
Red and blue thread locker to secure the driven gear bolt into the stub (red) and the oil pump bolts (blue).
All BELTS EXCEPT TIMING BELT & balance belt as that is being shitcanned...
6 Quarts of Synthetic motor oil - 20W - 50.
SPARK PLUG WIRE SET - Standard Ignition P/N 7479 OR BEST HIGH TEMP AVAILABLE
Metric Tap & Die Set
POWER STEERING HOSE - 5 FOOT
All other Hoses
AFTERMARKET OIL COOLER KIT P/N 459 in lieu of Mitsu p/n MD 157670.... 1990 oil filter mount - the one with the fittings for remote oil cooler - & a 90 Oil Cooler itself...
Front Drivers side CV joints & drive shaft assembly.
Inner Wheel Bearing Seal
Cat Converter Gaskets
HandCleaner - 1 gallon
Parts Cleaner - 1 gallon
Purple degreaser - 1 gallon
With a 4g motor, they are not neccesarily (sp) stretch to tq, when you pull the bolts out, lay the threads on a metal straight edge, if all threads touch, they are good, if not, they have infact stretched which can happen. Since you have it off though, I would go ahead and put ARP studs in it, they are no very expensive, less than 100 bucks and you don't have to worry about it anymore.
Alright, that is good to hear. I am kind of working on a budget (in other words I don't have any money :D ) I am going to pull the head off today and see what is going on. I have a motor that was locked up right after putting a new head on it about two months ago. That is the head that I am going to use so I am almost certain that all of the gaskets in it are still good.
Oh, and I'm located in Columbia so I am not that far from you Buck.
David :talon:
