Headlight/Inside Lights ground?
BGRIPTP
938
May 29, 2003
Parma Hts., Ohio
Where would my headlights/dash lights ground be? They dont work and I checked/replaced all the fuses under the hood/driver side kick door, you think it could be a bad ground?
If I remember right there are at least 3 different grounds for dash/headlights.What gives you the idea the ground is at fault?Did you unplug one of the lights and test for power and ground?
