Benji
- 117
- Mar 14, 2003
First, I am running a MAF-T/3" Maf in blow through setup. I have been running this setup for several months. This last weekend I decided to replace my intercooler couplers with better ones as well as T-bolt clamps instead of using the worm type clamps. Needless to say, I also swapped my ECU for one I had bought.
After getting the car back together I checked for boost leaks and everything seemed to be fine. I started the car and drove for about 20 miles and it ran awesome. The car sat for several hours and then was started again.
Now ever since the car will stutter/hesitate in boost. First thing I did is swapped back to my old ecu. Same thing. I have been logging and found something really strange.
The o2 Voltage cycles normal while cruising but as soon as I hit the throttle, the o2's will drop between 0.04V and 0.08V ...
This happens with both ECU's.
