Oscillating idle
cwo4vr55
Nov 9, 2003
After my 92 Laser has warmed up the idle speed seems to fluctuate between 400 and 900 rpm. It does not run rough when accelerating only at idle. I changed plugs and plug wires. Hope someone can give this beginner some tips, I have the Haynes Repair manual just want to go in the right direction
Bob
Test the ISC motor if it is operating properly. It is one of the most common problems with idle surge. To test check vfaq.com, they have a step by step procedure to accomplish it.
Hope that helps,
Steve
I have not yet made any changes to the MAS I have only installed a K&N cold air kit and the car was idling rough before then. I not check timing yet. I am planning on installing a Stage 1 G-Box which gets spliced into wires 4 and 6 of the connector for the MAS/IAT. Hope you help me out here bro
Bob
I am haveing a similar problem but my idle ranges from 500 to 2000. it doesnt surge all of the time some times it will hold a steady rpm. i start the car and the idle is 2000 it might stay that way all day or it might change when it drops past 700 it tries to stall. i have checked for vacu. leaks but nothing. i am running out of ideas. oh and about 4 gallons of fuel that is in my tank is about 8 months old.
