oil leak on drivers side
datsun510dude
Sep 29, 2002
Ok, heres the deal im getting a nasty oil leak on the drivers side of the engine. Its causeing oil to go down the bottom of the drivers side of the car. Anyone know what it might be? The main seal was jus replaced too...so is there anything on the drivers side, near the oil filter that might potentially leak? Anything that usually leaks? Anything will help.
thanks
josh:thumb:
thanks
josh:thumb:
Check if your oil filter and/or oil filter backed out, that’s what it sounds like to me.
no oil by the crank... um im still lost on what it is, it might be the oil filter mout thingie (sorry loss for words right now hahaha)
Did you near teh rear main seal, or the oil supply/return lines? Those run from the pan to the oil filter and block etc..
Originally posted by PhoenixRPR
Cam seals, oil supply line, or oil return line.
Dud it's the oil filter housing coming loose fix it ASAP or you will be needing rod bearings soon.
because of lack of oil, or that crushed innerds thing where the coolant and oil mix?
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
