rebuilt my engine, now have all kinds off problems
200Eclipse
Aug 20, 2003
ok lets see here,
i just finished rebuilding my first engine last week, it started on the first crank , now i am have all kinds of problems with it:
- low oil pressure, its fine when i first start the car, but after about 5 min it starts to go down.
- low compression, i hope i fixed this problem cause i pulled the head back off and got it rebuilt (since i didn't do it the first time), i know all the exhaust valves had a lot of carbon build up, just wasn't sure if this would cause the problem or not (not sealing properly??). and the sleeves were shot
- and a weired knocking noise when the engine is at 2k on up, i'm hoping this problem is solved now that the head is rebuilt
they only thing i realy did was leave the belt off the silent shaft, but i left the shaft in.... would this cause low oil pressure? becides this, i followed the haynes book........
-Shawn
aaaaaaaaahhhhhhhhhhhh................
i put it all back to gether today and now my compression is all screwed up,
ok before i rebult the head, cylinder #1 was the lowest, thew othe 3 were all even
now cylinder #1 is the highest, and 2, 3 & 4 are low. (40psi diff)
dose it take time for the valves to seal? all i ever worked on before were rx-7s, this is the first piston engine i ever realy worked on (rebuilt) do i have to run it for a while to set the seals? i can use anykinda help right now, i am completly lost
-Shawn
yes the entire engine was rebuilt, i did a leak down test, its the rings :cry: , so now i am gonna have too pull it alll back apart and change them agian :mad: , y would the rings be bad already? i might have had ran the engine a hole hour total since the rebuild
-Shawn
-Didn't compress the rings correctly while putting the pistons in, the ring gap score the combustion chamber wall, I had to rebore the block and get one size up piston set, then another time after having the shop bore out the block, I didn't clean out the oil passages good enough, fine steel shaving damage all the crank bearing before being trap by the oil filter, so live and learn, good luck.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
