cracked manifold harmful?
gunnmetal
61
Aug 25, 2003
heres my story:
bought a 1995 shell GS
but a 97 engine(got screwd hard) smoking leaking oil
got all seals,gaskets,belt replaced
1 injector replaced intake cleaned
cracked manifold....
whats next????????
listen whos got a 2g manifold in mint condition for sale.
It depends on the manifold:
Intake Manifold:
You'll run lean with vacuum, rich under boost. Get it fixed ASAP, if it's a large crack, don't drive the car like this.
Exhaust Manifold:
Not a huge problem, it happens. It can cause a lag in boost, lower your maximum possible boost, and eventually causes a mess around the cracked area. A good idea to fix if you have the time, or are doing something in the area anyway.
-Jesse
everything you said it true it is kinda hot in the engine bay
thanks a lot
as for the power im getting my car back today new vavle seals and head gasket replaced no mor leaking oil and no more smoking ( i hope so)
i agree, but have to elaborate more. If it leaks near intake runner 3 & 4, your car would run exactly what Jesse described.
However if it leaks near runner 1 & 2, your car will run lean at idle, part throtlle, and WOT (basically running lean entire fuel curve). Why? If you get leaks near 1 & 2, fuel pressure would drop because FPR vac line connects to intake runner 2. I ran like this for 1 month and guess what cylinder 1 & 2 loss 15 psi compression (down to 145psi). Good luck.
Intake Manifold:
Exhaust Manifold:
-Jesse
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
