Robby Camero
- 101
- Oct 27, 2003
Toronto,
ON, Canada
Ok, I also have a 90 tsi fwd which isnt listed in my profile which I use as a winter beater and she is acting very strangly. It pulls hard still but idles very badly. Studdering, and almost stalling. Trims are pegged full at 120% (90 ecu), o2 wont cycle and no error codes. I know what your all gonna try and tell me already so here is a list of things I have checked.
-intake leak test, no leaks under 28 psi
-new o2 sensor
-new fuel filter
-cleaned injectors
-relpaced almost every vaccume line with new ones
-cleaned throttle body, tried another one as well
-adjusted the base idle untill I was blue in the face, no change or efect
-checked timing FOUR TIMES, crank, cam and oil pump marks are deadly and I did the ruler check accross the cam marks
-tried two different mafs
-tried two coil packs
-replaced power transistor
-blocked EGR
-new wires, plugs etc...
-new pcv valve
heres what I havent done yet
-try another ecu
-compression test (friend lost my tester)
-swap CAS (but I should be getting a code if it faulty right?)
-Check crank sensor
-swap injectors
I am stumped! Could a dead cylender cause this problem? I know a copression test has to be done but I am just waiting for a replacement from my friend. Have fun trying to figure this one out.
Thanx
-new o2 sensor
-new fuel filter
-cleaned injectors
-blocked EGR
-new pcv valve
-try another ecu
-Check crank sensor
-swap injectors
Thanx
