11secDSM
- 749
- 9
- Sep 8, 2003
Collegeville,
Pennsylvania
I just got back from a two hour road trip. On my way home, I started hearing a vibration coming from my driveline. It progressively got worse. Then when I pressed the clutch in, it got WAY worse. By the time I got home, it sounded like my car was about to fall apart. Under hard cornering, you can hear it and also when you press the clutch in. It is a griding/vibrating type of noise. The weird thing is that it happened all of a sudden under highway crusing conditions. Can anyone PLEASE help me diagnose this problem? Broken axle? Clutch problem? Driveshaft problem? I have a brand new ACT 2600 in and it has not given me any problems. I really have no idea what the noise/grinding is coming from! Please HELP! Thanks!
Just put a new motor in and now, THIS! ugh! ..the saga continues..........
