gtidriver
- Oct 17, 2003
hey everyone im a noob but ive got an interesting ? i recently switched to a big 16g part of the reason being that on the 14b i had terrible overboost probs. i was spiking to 20+ psi on stock fuel system minus a pump. tried everything on that including, as per advice from extreme motorsports, removing the boost solenoid and running a straight vacuum to the wastgate t'd into the bov(was "supposed to" give me 100% guaranteed 14.7 psi because that is the limit on the wg diaphragm) this still didnt work. car ran ok but scared of damage. now ive put the 16g on after porting the o2 hous. more behind the wg flap for further opening ability and now i cant get boost any higher than 10 psi???
once again tried w/ and w/o the boost solenoid in place with no success. i need major help! thinking about seeing if a mbc will solve this prob. thanks for any input. later
also do you think the overboost issues from before could have been from the small turbo, 3" exhaust, no cat. combo? thats what extreme told me was wrong before and i guess it sounds pretty logical. thanks again.
